I need the gear cable for a old Shimano 3CC 3 speed hub...if anyone has one or knows where I could get one I would be thankful...the one I have has cable housing damage...if anyone knows how I could fix it that would be great too...thx
You could also get the correct toggle and shifter and convert it to use a standard cable, but in the end that would probably cost as much or more than the positron cable.
modern 4mm sis housing is the same ad what they used on the positron cable set. The only thing you will have to rig, is where the cable housing connects to the plastic end that attaches to the shifter.
Modern She-man-o will work on a 3 speed replaced with a Shimano 333 shifter , bell crank and cable.
The positron was introduced to make the adjustment more 'Idi*t' proof.
