RAN ACROSS THIS very-stout, 19th century, John Deere bicycle badge back in June, on e-b. Believe it was
classed under farm implements and not bicycles .. the bids were well over five-hundred simoleons by the time
i went on the peep. Doing a little detective work enabled me to know that the majority of players were well-
schooled in the capture of genuinely-rare AND desireable, early, John Deere artifacts. i really enjoy the linear
quality that makes form visible. The badge has an earlier quality that suggests woodcut-printing.
INITIALLY THOUGHT THIS BADGE was made using acid-etch methods ... that is, the bright part of the badge
(the high area of visible brass) was silkscreened with an acid-resisting mask, the mask having a negative area
design (all the black lines that make the deer and the word-content visible) ... this negative, design area would
allow acid to pass thru .. to attack and etch the brass plate that is the badge. On closer inspection, i believe the
design was rolled-on by a hardened-steel cylinder having the same design that appears on the badge ... only back-
wards and in high and sharp relief. This theory was developed noting the badge design does not have any broad
or wide areas of low-laying, black areas of information on the badge proper ... the appearance of broad or wide low-
laying areas of information would necessitate the use of silkscreen methods. i could be wrong.
Much more research is indicated, before a conclusion can be reached.
......... patric
