Silver king seat post qustions
Rustngrease
Apr 2, 2019
151
37
Tokeland
I pick up this frame from a member here, 1936 king , was wondering how this seat post was set up, if there's a set screw to drill out and how I could go about repair, any pics and info would be much appreciated.
Cheers
Reactions: New Mexico Brant
piercer_99
2,076
59
Sanger, TX
you are going to need a Silver King specialist on this.
I am pretty sure you have the issue where the steel has bonded to the aluminum frame.
I know how to get an aluminum seat post out of a steel frame, but that information on this would dissolve your bicycle and I am pretty sure you want the bike more than the post.
I am pretty sure that you are dealing with galvanic or bimetallic corrosion here. The main problem is the chrome seat post and aluminum don't mix well, there should have been a layer of grease between them. I don't know if there is an easy solution for you.
Frosty
May 12, 2016
174
44
San Jose, ca.
Should have had a quil style seatpost. Like a gooseneck works. No set screws or pins. Have you remove the quil bolt or is that how it came.
Sent from my Z982 using Tapatalk
Rustngrease
Apr 2, 2019
151
37
Tokeland
That's how it came to me, I would use it how it is, but would be nice to have a little more length
99 bikes
52
49
Washington, United States
I had the same issue with my SK seatpost.
I started by soaking it forever, and it still wouldn't budge. I finally resorted to cutting the very top of the post off, then using a hacksaw blade carefully cut the seatpost from the inside working outward. It was slow going but worked like a charm.
Dope54
Mar 26, 2009
167
Westminster, United States
Ahh yes. Yeah try pb blaster and heat. That’s what worked for me
