Silver king seat post stuck
Discussion in 'Classic Balloon Tire Bicycles 1933-1965' started by Dope54, Aug 22, 2017.
  1. #1 Posted Aug 22, 2017
    Mar 26, 2009
    138
    18
    Westminster, United States
    IMG_1443.JPG IMG_1444.JPG Hey I just picked up a men's silver king with a stuck seat post. I've soaked it when penetrating oil for 2 weeks with now luck. The bolt can be removed and the wedge seems to stay in place in the tube. Also put a saddle on it and tried to work it back and forth with no luck. How can I get this thing out ?
    Kstone likes this.
  2. #2 Posted Aug 22, 2017
    Dec 14, 2013
    71
    30
    Antioch California
    You can try heat but tread lightly as to not get the frame red hot. By heating it you might get the aluminum to expand just a little bit thus removing the seat post wedge
    Sent from my Pixel XL using Tapatalk
  3. #3 Posted Aug 22, 2017
    Jun 12, 2016
    586
    960
    Eureka, CA
    You are going to hear a variety of suggestions ranging from secret sauces to vibration to heat, all with back and forth tension with pipe wrenches or vises. Don't twist the aluminum to death.
    Don't forget to turn the bike upside down and drench the post from the bottom.
    If all of these fail, you're gonna have to drill the beast out. Make no attempts to hog it out in one go. Start with the smallest bit possible and work your way up in 1/16 inchcrements! This will keep you centered in the post. I you cut off the protruding part of the post, you can use normal length drill bits. Keep us posted.
    Did you tap down on the bolt to displace the wedge?
    Kickstand3 and 56 Vette like this.
  4. #4 Posted Aug 22, 2017
    Mar 26, 2009
    138
    18
    Yeah I have been soaking it from the bottom as well. Yes the wedge moves a bit
  5. #5 Posted Aug 22, 2017
    Mar 26, 2009
    138
    18
    Heat the frame from the outside and not the post right ?
  6. #6 Posted Aug 22, 2017
    Jun 12, 2016
    586
    960
    Eureka, CA
    June 5th post. tips or tricks to removing seat post.
    Harley Mclemore likes this.
  7. #7 Posted Aug 22, 2017
    Riding a '37 Colson Imperial
    Mar 4, 2012
    12,896
    16,275
    East Los
  8. #8 Posted Aug 22, 2017
    Dec 21, 2014
    580
    334
    Grand Prairie, United States
    I'll call you later
    Dope54 likes this.
  9. #9 Posted Aug 22, 2017
    Dec 14, 2013
    71
    30
    Antioch California
    Yeah but be very careful. Aluminum melts alot faster then steel. Maybe have a welding buddy help out. I would hate to hear that the frame warped or even melted due to my advice. You could always try water first. Soak the whole thing in water for a few days and see if that does the trick
    Dope54 and mike j like this.
  10. #10 Posted Aug 22, 2017
    Mar 22, 2013
    180
    134
    Wichita, KS, United States
    LOL i left mine in there as it was stuck at the perfect height. Mine doesnt even have a sleeve and bolt in and it doesn't budge
    Dope54 and Harley Mclemore like this.
  11. #11 Posted Aug 22, 2017
    Mar 26, 2009
    138
    18
    Any type of solution?
  12. #12 Posted Aug 23, 2017
    Jul 16, 2009
    636
    72
    Holmen, United States
    Found this info years ago online. Kano Kroil seems to be one of the best.
    Machinist's Workshop Magazine discussed solvents used for freeing frozen parts. They found in freeing a frozen part:
    Product / Average load / Price for each fluid ounce
    • None / Required 516 pounds of force to free / (no cost)
    • WD-40 / 238 pounds / $0.25
    • PB Blaster / 214 pounds / $0.35
    • Liquid Wrench / 127 pounds / $0.21
    • Kano Kroil / 106 pounds / $0.75
    • Auto Transmission Fluid (ATF)-Acetone mix / 53 pounds / $0.10
      NOTE: do NOT attempt to use the ATF-Acetone mix on anything with paint or near paint. The Acetone will compromise the paint it touches. Go with Kroil or Liquid Wrench instead.
    TR6SC and 56 Vette like this.
  13. #13 Posted Aug 23, 2017
    Nov 21, 2014
    605
    602
    Arcadia Ohio
    Good luck, patience and soaking worked for me. My post must not have been stuck as bad as yours, but what worked for me was to unscrew the post wedge bolt a few threads and whack it to get the wedge loosened up. Took the bolt out and every morning and every night for five days I sprayed PB blaster in the hole and around the shim, and whacked the post once and put the bolt back in and whacked it to loosen the wedge more. After 3 days the wedge fell to the bottom bracket, then for the last 2 days, sprayed the hole and around the shim and now gave a back and forth turn with a pipe wrench where the seat clamps, not too much pressure though, and 1 or 2 whacks on the post. On the 5th day the post actually creaked and moved a little bit, I worked it back and forth slowly for about a half hour, until I could spin it all the way around and then it worked it's way up until it came out. Luckily I didn't have to drill it out or do any damage to the post the shim or the frame. Best of luck! Joe
    dnc1, TR6SC and Dope54 like this.
  14. #14 Posted Aug 27, 2017
    Mar 26, 2009
    138
    18
    pb blaster hasn't worked. Kano either. I'm going to try vinegar tomorrow. Just wanted to update you guys
  15. #15 Posted Aug 29, 2017
    Aug 28, 2016
    282
    144
    New Lenox Illinois
    Put the seat post in a bike stand with the rest of the bike hanging and keep soaking it
  16. #16 Posted Aug 29, 2017
    Aug 28, 2016
    282
    144
    New Lenox Illinois
    Or try hitting it straight down, you can always go fishing for it after it's moved
    Dope54 likes this.
  17. #17 Posted Sep 3, 2017
    Jun 12, 2017
    389
    226
    Dunn, NC
    Hey, Been playing with an old Dayton frame that had a stuck stem in the fork. Soaked it for a couple of days with PB Blaster... Nothing.. Wouldn`t move a hair... Wedge had dropped down but stem wouldn`t budge. Something that worked not long ago and worked again today--
    sounds STUPID -- but two times in one week --PINESOL--put it in a spray bottle... It might be a coincidence... might be a reaction between the PB and the Pinesol. Cost you two dollars--TRY IT!---God Bless---Cowboy If it works for you--- I`m gonna Patent the idea !!!
    Yes, I know what you`re thinking- He`s old... This trick worked previously on a Schwinn Phantom seat post. Soaked it - nothing... added the Pinesol--- fifteen minutes. Same with the stem-- I don`t know why it works, but I`ll use it again. Good Luck--Hope it works for you...
    #17 Cowboy in NC, Sep 3, 2017
    Dope54 likes this.
  18. #18 Posted Sep 7, 2017
    Jun 12, 2017
    389
    226
    Dunn, NC
    DID YOU TRY IT?----------Cowboy
  19. #19 Posted Sep 13, 2017
    Mar 26, 2009
    138
    18
    Oh it finally came out! I soaked it forever in PB blaster and then pinesol . Finally I took heat to it, a lot of heat! I would heat it up then cool it with pb then heat again. After the 3rd time put a pipe wrench to it..... and bam it started to wiggle! Thanks for all the suggestions guys ! IMG_2007.JPG IMG_2006.JPG IMG_2008.JPG IMG_2009.JPG
    buickmike and TR6SC like this.
  20. #20 Posted Sep 13, 2017
    Jun 12, 2016
    586
    960
    Eureka, CA
    Cowboy in NC and Dope54 like this.
