I have a very cheap Sunlite one from my LBS that had some little tabs in the middle to center up a chain. I broke them off to fit the skiptooth and bottoming out the tool pushes the pins to the perfect depth so I can pull the links apart without popping the pin entirely. I paid like 5$ for mine and it is cheap but I've used the crap out of it and the pin is bent but it hasn't busted completely up yet.
Thats exactly what my friend and I did when I got my Huffman. Anything skiptooth is unknown up here so we modified a regular chainbreaker just as you described, it worked great!
Will these Park breakers work perhaps? They get very good reviews and I'm okay with spending a few extra bucks on quality tools. The Sunlite one got some mixed reviews.
I'm sure something like that would work too if you bust those center tabs out. The cheapo sunlite one has a plastic body so it was quite easy. The skiptooths are generally wider than the chain it's designed for. Yes, Buster, I can still use it for 1/2" pitch just fine.
