Skip tooth front sprocket replacement
Old is Gold
I have this skip tooth sprocket on my 1950 Roadmaster and I am thinking about switching it over to a more standard 1/2 x 1/8 pitch sprocket and I was wondering if someone might have one that I could purchase?
The diameter of the sprocket appears to be approximately 8 5/8 OD + or - a bit.
I could even live with a little smaller OD if need be to make it a little easier to pedal. I am not sure if this was a correct place to post this so I might put it in the parts wanted forum as well.
Thank you
I believe that there was a 24 tooth version of that same style of sprocket, if the gear ratio is the primary reason for wanting the change.
I've seen that sprocket in standard 1/2x1/8. I've had it in the past.
Anyone have any clue words to look it up? It must be similar to others
on lower end bikes?
