Sources for Teen era Head tube bearings
Bozman
Aug 6, 2009
739
839
Alexandria, Virginia United States
#1
Restoring a 1913 Columbia Model 312 and need smaller sized head tube bearings. 5/32 inch bearings, with 17 ball bearings and 1 7/16 inch outer diameter.
So now that Memory Lane is but a memory where can I find these bearings and other odd size bearings?
Need one but would like to have 5 so I can have a few in stock for other projects.
Thanks in advance
Boz
Sent from my SM-N910V using Tapatalk
Jesse McCauley
McCauley Cycle Works
Mar 5, 2013
2,012
4,109
Richmond, Virginia
#2
I’ve got a large stash of NOS teens/ twenties bearings JD, I’ll put some up for sale when I get home from Hershey
Likes: Bozman
Bozman
Aug 6, 2009
739
839
#3
Thank you my brother! By the way I just mounted the skiptooth chain I got from you on my restored 1915 Pope manufactured Lenox
mickeyc
2,990
2,173
Rochester Hills, MI
#4
I have 4 proper O.D. and bearing size, but only 16 bearings each. see photos. You are welcome to them.
Mike
Likes: Bozman
Bozman
Aug 6, 2009
739
839
#7
Another option is to buy loose 5/32 ball bearings and install into your bearing races using grease to keep them in place while assembling. Since they are not caged, one or two extra balls will fit.
I might have to do that on my 1898 Montgomery Ward Hawthorne. They have REALLY small 16 bearing bearings.
locomotion
2,630
1,575
QC
#8
I would suggest just using loose bearings if you can't find the correct size of caged bearings.
they are pretty easy to use, just put some grease in the corner of the cups and stick them in there one next to the other.
I have 100's for different sizes if caged bearings
I will check if i have the correct size for you, if I do I will PM you and sell them to you for FREE :)
nothing better to help finish up a bike when only the bearings are the missing pieces
Archie Sturmer
Jun 13, 2018
887
799
Los Angeles, CA, USA
#9
I have found these odd 17 x 5/32 bearings on later 20s and early 30s Westfield bikes; they also had odd cup sizes (about 31 mm) and 1”-26 threads per inch top cone and top nut.
Likes: Bozman
Bozman
Aug 6, 2009
739
839
#10
Mike View attachment 881470
Sadly Mike these bearings are a fraction too large in diameter. I really need the 17 bearing model. Looks like I'll have to just use loose bearings packed in grease.
Boz
