SKPC
If just one spoke is busted, put the new one in and 1st tension it to about the same(by feel) as the others around it. Put the wheel in the dropout in your upside down bike, and while holding a little screwdriver close to the rim, spin the wheel and where the rim hits the screwdriver, loosen the nipple on the side of the hub where it hits the screwdriver, or tighten the nipple(s) on the other side, which will pull the rim back the other direction.
Impossible for us to know what your spoke tensions are currently, or what spokes are loose and which are tight, but generally it is a good idea to grab two spokes between your fingers and just flex them by feel all the way around(both sides). You may notice some are looser or tighter than others, maybe not. If some feel too loose, tighten them a 1/2 turn to more closely match the feel of the others, then do the screwdriver thing again...this should work for you.
If you are starting over, see @cyclingday 's very clear and happ'nin post above. It takes practice and patience for sure.
IMO, when it comes to building or trueing wheels, your mind is far superior to anything else you think might help you......
