Springer fork question
oimakoi
Is the spring in the springer fork on these 53 SD models supposed to be stiff? There is no movement/bounce when i ride it and even when i purposely push down the front end holding it by the handlebar near the stem then pushing it down...no bounce whatsoever...
Try some lube on the bolt that is surrounded by the spring. The fork should move with moderate pressure on the handle bars.
