D
dogsridewith
Guest
Maybe someone here would be kind enough to offer suggestions for my search. The apparent original bolt, of the four required, is a 5/16 thread shoulder bolt with a 7/16 diameter shoulder about 5/32 long. Bolt length, excluding head, per convention, is about .570 inch. Shallow hex head is .630 across flats.
I suspect similar bolts used on other springers. I would use any alternative fastener arrangement that provides similar function. Hopefully won't have to cut short bushings out of tube to fit over 5/16 bolts.
Thanks.
Thanks.
