There’s no carburetor or magneto visible on the engine of the tandem. That means we likely have a surface carb and trembler coil in the box in front of the motor, which was primitive even for that time.
The surface carb was literally a can, kept full fuel by a float, through which you drew the air for the motor. The fuel used was more volatile than gasoline, benzine I think, and so you hoped your intake air picked up enough fumes on the way through the can to create decent mixture. Some surface carbs were packed with cotton fibres to increase the surface area. A trembler coil was a battery operated ignition device which vibrated a magnetic core in a coil creating a continuous series of sparks.
So you hoped you got a strong enough mixture into your cylinder for your continuous series of sparks to ignite once it was compressed enough up against your mica insulated sparking plug. These motors only ran at a few hundred rpm, which explains the lack of a more drastic gear reduction before the rear wheel.
There are few survivors of “motorbikes” with these motors as the semi open can of fuel type of carburetor tends to spill onto the hot engine and burn the entire thing to the ground if the bike falls over.
Another early ignition system was the hot tube system. This is where you had a tube of platinum screwed into the head of the engine, the outside of the tube surrounded by a box into which you place a lit bunsen burner. This heated the tube to a glow, when this heat worked its way through into the combustion chamber it hopefully ignited your compressed fuel mixture. Trembler coils Were an improvement, and possibly less of a fire hazard.
