Stiffer Shelby shock ease spring?
fullcircle
95
48
Lockeford, CA
Has anyone found a stiffer Shelby shock ease spring. I added a few washers to the original orange spring it helped but would like it to be a little stiffer. If I lean forward on the bike the fork will pivot forward.
Thanks Tom
Archie Sturmer
1,433
Los Angeles, CA, USA
Orange rust?
Modern springs are color coded; the heavier duty ones might be green or brown, depending on which color coding system that the manufacturer uses.
Many springs are available from China and use metric dimensions. A 20mm outside diameter spring should fit inside the steering tube; the inside diameter (10mm?) should fit a 3/8” bolt. The length should be about the same as the original, if original (65mm?).
Reactions: New Mexico Brant
Archie Sturmer
1,433
fullcircle
95
48
Lockeford, CA
Jim had a brown spring on hand to try and it works perfectly for me on the bike
fullcircle
95
48
Lockeford, CA
looks like that green spring is heavier than the brown good to know in case I want to go stiffer
