stripping paint
Discussion in 'General Discussion About Old Bicycles' started by buck hughes, Dec 26, 2017.
Tags:
  1. #1 Posted Dec 26, 2017
    Jan 23, 2016
    676
    1,573
    lima oh
    need to strip paint-is it possible to strip off the blue with out going through the original paint?
  2. #2 Posted Dec 26, 2017
    Oct 2, 2011
    4,370
    2,432
    Bismarck, United States
    I've had some great luck with Goof Off, oven cleaner for oil based paints. Oven cleaner works pretty fast and can spread to adjacent areas that might cause damage, use with caution.
    Maybe try a small spot next to that bare metal chip , as a test.
  3. #3 Posted Dec 26, 2017
    Oct 2, 2011
    4,370
    2,432
    Whatever product you choose, test it on the red paint underside of the rack to see if it acts on it quickly or not
    retrobuilder and Kickstand3 like this.
  4. #4 Posted Dec 26, 2017
    Jun 2, 2017
    790
    979
    Greenwood Arkansas
    Paint thinner on a Q-tip to see if it cuts the blue the base color looks like it's pretty tough industrial coating might even be baked on as a corrosion prevention method?
  5. #5 Posted Dec 27, 2017
    Oct 8, 2017
    110
    40
    Alpharetta, GA
    Maybe it's latex paint.
    Always start with the weakest solution first. Then step up to stronger solution.
    I'd use IN ORDER
    1. USE A HOT AIR GUN AND SOFTEN THE LETTERS. FOCUS ON THE LETTERS ONE AT A TIME.
    2.simple green first and soften the paint
    3. mineral spirits soak 1-5 minutes soften the paint
    4. enamel thinner soak same way.
    Use a tooth brush as it looks like textured paint..going to make it hard to do completely.
  6. #6 Posted Dec 27, 2017
    Oct 16, 2008
    4,632
    3,341
    Seattle, United States
    Leave it you’ll regret it...:0
    Barto and partsguy like this.
  7. #7 Posted Dec 27, 2017
    Oct 8, 2017
    110
    40
    Alpharetta, GA
    That's why I suggest a hot air gun.
    Notice the chipping paint in corners. That will likely peel off the adjacent color.paint with any solvent.
    Also --Soaking in hot water maybe worth a first try- but to redlines point.."beware".
  8. #8 Posted Dec 27, 2017
    Oct 8, 2017
    110
    40
    Alpharetta, GA
    Another option is to simply paint over it with a small texture foam roller using craft paint blended close to the color.
    remove the two screws.
    Apply it in two localized light coats...
    That way you get the texture and exposed chipped paint
  9. #9 Posted Dec 27, 2017
    Jul 14, 2009
    14,346
    13,338
    Evans, GA
    Buck just change your name to "Dick Lantgen" and you're good!
  10. #10 Posted Dec 27, 2017
    Aug 13, 2008
    10,213
    3,805
    The Land of Oz
    Buck, this won't end well:
    redline1968 and bikemonkey like this.
  11. #11 Posted Dec 28, 2017
    Jan 23, 2016
    676
    1,573
    lima oh
    so far I used goof off-then rubbing alcohol-then hot water no matter how light you rub it-it goes right to the red and starts lifting the red. I will keep trying as I am not one to leave the name on this radio!
  12. #12 Posted Dec 28, 2017
    Aug 13, 2008
    10,213
    3,805
    The Land of Oz
    I think trying to remove it will ultimately damage this rare radio far more than leaving it alone. Here is an idea not mentioned, take the radio in for a laser paint match, and touch up the paint to cover the name.
  13. #13 Posted Dec 28, 2017
    Jan 23, 2016
    676
    1,573
    lima oh
    where do you go to get laser match?
    partsguy likes this.
  14. #14 Posted Dec 28, 2017
    Aug 13, 2008
    10,213
    3,805
    The Land of Oz
  15. #15 Posted Dec 28, 2017
    Jan 23, 2016
    676
    1,573
    lima oh
    thanks for every one's input- ended up going to Sherman Williams they did a laser match I just painted over the blue-someday I might find an original painted back cover. thanks to all!
    WetDogGraphix likes this.
  16. #16 Posted Dec 28, 2017
    Oct 8, 2017
    110
    40
    Alpharetta, GA
    From what I see I would roll a second light coat red.using a texture foam roller then lightly clear coat entire wrinkle finish cover for closer gloss..
    The red looks close- just low gloss.?
    The goof off likely softened it to metal and anything you do will lift it. at this point.- GOOD LUCK.
