stuck crank bearing retainer 1894 Columbia
VITAL.SPARK
35
Central District, Hong Kong
I'm having trouble removing the crank bearing lock nut on the 1894 Columbia. I've tried numerous soaks with liquid wrench, heating with a pencil torch, hits with a brass rod, and C spanner. I really don't want to damage these 124 year old antique parts as they aren't replaceable! I would think the lock nut has a left hand thread as it's on the left side of the bike but have tried both directions just in case. Any suggestions?
Reactions: 1951 C.W.S
bikiba
2,088
NYC
going back and forth in both directions a bit has worked for me in the past. Where i couldnt dislodge a nut or ring etc in the off direction, would sometimes move a bit in the tightening direction and would give me a little play.
i agree with the above post... more chemicals for more days and dont rush it - like you said, if you break it, it is broken! :)
Reactions: VITAL.SPARK
sam
1,476
San Antonio, United States
Can't tell you where to find one, but what you need is a two handed adjustable spanner. Locks into both sides at the same time putting even pressure on the nut.
Reactions: Igor
VITAL.SPARK
35
You mean like a left handed monkey wrench!
Craig Allen
Jun 23, 2016
167
65
Millville NJ
www.mscdirect.com
Order #95327714 about 55 bucks with shipping. There are other more elaborate spanners available but they can run into the hundreds of dollars. This spanner has two 1/8" pins. You
Craig Allen
Jun 23, 2016
167
65
Millville NJ
Order # 95327714 about 55 bucks with shipping. There are other more elaborate spanners available but they can run into the hundreds of dollars. This spanner has two 1/8" pins. You can probably wrap vise grips around the wrench for torque. Sometimes with these old bikes all that is needed is more elbow grease and a little less timidity in breaking something. I'm thinking the bearing race has left hand threads and the nut had right hand.
VITAL.SPARK
35
I have a 2 pin wrench as shown but it's too fragile for this work. I'm going into town Friday and pick up a adjustable hook wrench as shown on the right. I'll then be able to put a pipe over it for more leverage. Interesting that you think the bearing race is left handed and the locknut right handed. this gives me another course of action! I assumed both were left handed?
