Finally got tired of staring at this one sitting outside the basement door and freed the stem up!
Started with re-soaking the pivot pins in the lowers, tapped them out with a punch .
Wanted the lower legs removed so I could mount the fork in the vice to have a place to twist and have a solid surface to back up the hammer blows. Wedge was very stuck. The stem bolt and 5/16" punch had no success and ended up blowing through the threads.
Sssooo, I ended up drilling the stem hole up to fit a 3/8" punch and went at it with the air hammer. No love!
It actually ended up swelling and chipping the punch, as you can see below. The punch was stuck and had to be tapped out from the bottom. That tapping was finally what broke the wedge loose.
Got a little bit of twist from the stem after that and it was on like Donkey Kong! Looking at the wedge after getting it out, it had been broken for years. The 5/16" punch may have split it at the threads though.
Now I need to find somebody to weld the legs back together....
