new2olbikes
It’s my first experience with these and it, (or I), may not be shifting properly. BACKGROUND: Got a cheap AMF Voyager(70’s?) w/ that shifter/hub combo. The hub stamp reads AW, also a 7 & 74 on either edges. I haven’t driven one of these so my question is what to expect? I have given the chain a good cleaning & lube, it feels a bit slack but not too loose, about 1” total play up/down. The trigger shifter has been WD’d & cleaned/ oiled, (not taken apart) & shot some into the cable housing it seems to move freely. I “filled” the hub w/WD, shot some all around the hub too, then did lots of hand cranking & shifting and it started to respond. I drained the hub, refilled & repeated the process, then got on it for a ride; fairly level street & went through the shifting process. Under load it seemed to not shift easily, if I stopped pedaling, then shifted it responded & I could detect a gear change,(feel). I let it soak overnight & today I’ll do another drain/refill & ride before putting in the regular oil, (3-1) or maybe ATF, which some have mentioned... So my?: Is the gearing difference subtle or a bit more dramatic,(that’s my guess), since it’s only 3 gears... & does it require a hesitation / pedaling or just back off the pressure? I’ll try tightening/adjusting the chain a bit as the next step. Then maybe attempting to adjust the shift cable but many say probably not necessary and it will be my 1st work on this type... I’m “exporting” this bike to PA for my daughter at school for a cheap ride. (No worry if damaged or stolen etc)... As always your comments & criticism are always appreciated. Thanks, Joe
