Survey - Patina or Stripped? Rebuilding wheels
KevinsBikes
Jun 21, 2016
418
454
39
Phoenix, AZ
#1
Can’t decide if I should attempt to strip these clad rims or not. They have been painted a few times I think which doesn’t look terrible but there is a glimmer of chrome/nickel which might look nicer? Open to ideas and opinions!
Likes: hoofhearted
9,950
8,391
Central Arizona
#5
I like to think outside of the box, sometimes it works out and sometimes it doesn't. I would get rid of that faux patina (barn paint) and get down to the "real" original patina. If you end up not liking the original patina, now hidden, you can go to Michaels and pick up a crinkle paint kit and recreate that faux patina. :p
cyclingday
6,244
19,595
Costa Mesa, California. United States
#7
Beauty is in the eye of the beholder.
I personally think those rims are gorgeous. Lol!
We usually cringe at a previous owners idea of nirvana, but sometimes, the authentic story they tell, is the story of that surfaces existence.
Rambler
Nov 1, 2011
762
689
Auburn Hills, United States
#8
My personal opinion, if you don't have a plan for these rims, than leave them alone, especially if you may end up selling them, leave this decision up the next owner. Also if it was the original paint I would be even more inclined to leave them alone.
However if you have a bike you plan to use these rims on and since the paint is not original, I think it doesn't much matter at this point what you do. If the bike you are putting the rims on matches the rims as-is then leave them alone. If the rims don't match the bike you plan to put them on then do what you wish with them.
CURTIS L LINDGREN
Dec 19, 2017
393
712
62
Bothell, WA, United States
#9
Have you ever stripped paint on these type of wheels before ? If you have, you'll know sometimes you get awesome results..............sometimes you then see WHY they were painted over in the first place.( Not so awesome results ) I agree with Rambler on this one ( "if you don't have a plan for these rims, than leave them alone, especially if you may end up selling them, leave this decision up the next owner. " ) I had mixed results with these wheels . Some real nice chrome ...............and some not so nice chrome. That's the chance you take.
KevinsBikes
Jun 21, 2016
418
454
39
Phoenix, AZ
#10
I plan to sell them, as I don’t have a bike for them. Now, I also have the dilemma to use stainless or galvanized spokes? Stainless are stronger but not original of course.
Rambler
Nov 1, 2011
762
689
#11
May I ask why you would bother building the rims up into complete wheels if you simply plan to sell them? Seems to me it's likely whatever selection of spokes or hubs that you choose it won't be quite right for the buyer. Might be better to sell the rims and hubs separately and may actually bring more money that way. Just my thoughts on the subject.
KevinsBikes
Jun 21, 2016
418
454
39
Phoenix, AZ
#12
I was figuring not everyone built wheels, and I enjoy the process. Your suggestion is good, maybe I will try that first and then build them and hold them for a future project.
KevinsBikes
Jun 21, 2016
418
454
39
Phoenix, AZ
#13
I agree & if you really want to go outside the box, I've had good luck w/ grooving metal clads for clinchers, then faux wood finishing them.
@mike j - what did you use to groove them? I have some other 28” which are worse shape I could practice on.
mike j
3,041
6,002
Tuxedo Park, United States
#14
I use a 4" electric grinder w/ a silicone carbide masonry cup wheel. They are available at Home Depot & most hardware stores for a couple of bucks. Get one that is wide enough for the tire bead to fit. I like them because they're not too aggressive. You are kind of half cutting & half burning the wood. It takes a couple of passes to get deep enough. The metal edge helps guide the grinder & adds strength to the side wall. I've found that Schwalbe 700 tires fit pretty nicely & ride fine. I believe @bikewhorder posted the process originally here & @Wayne Adam helped me w/ the faux finish. Good luck w/ it.
Likes: manuel rivera
bikewhorder
6,983
6,488
Midcoast, ME
#15
I used a 1/4" diameter core box bit with a simple router table jig. I thought the radius might help preserve some of the strength of the rim. At first I thought I could just rout two groves but it helps to deepen the whole rim so you can put the tire on from one side.
Likes: KevinsBikes
KevinsBikes
Jun 21, 2016
418
454
39
Phoenix, AZ
#16
I tried shortly on a rough one I have, I just wanted to see if I was on the right track? I did try and go along the metal lightly - seems to chew up that wheel pretty good though. I couldn’t find the original post with full instructions or pictures.
KevinsBikes
Jun 21, 2016
418
454
39
Phoenix, AZ
#17
I used a 1/4" diameter core box bit with a simple router table jig. I thought the radius might help preserve some of the strength of the rim. At first I thought I could just rout two groves but it helps to deepen the whole rim so you can put the tire on from one side. View attachment 931880
Do you have any photos of what it looked like after routing, without the tire on? Thanks!
CURTIS L LINDGREN
Dec 19, 2017
393
712
62
#19
Here's the thread: https://thecabe.com/forum/threads/i-made-some-wheel-progress-recently.27120/ The method you're using probably isn't the easiest or most accurate way to do it but it should work.
Thanks for putting the link up. I needed this info for my Hawthorne Flyer. Now I have the option to run a modern tire . I still have a ways to go ,but it started with just the Frame,Forks and Crank. This is my 1st 28" wheel bike . It's a different bike for sure. I dig the larger diameter. They (these bikes) have such a cool look to them . This is the 2nd bike I have "Pieced " together. The 1st bike I pieced together is the one in the second picture. Although some people don't care for this method., I'm having fun and learning a lot. Always had proper bikes before these two. I'm Learning more every day 'bout these 28" ers
Likes: KevinsBikes
willswares1220
1,914
679
Port Washington, WI
#20
Even if you build them , the experience alone you'd get would be valuable, plus the reward factor to boot!
You have to start somewhere to gain experience.....;)
Also, maybe you could find some old spokes to use, to keep that patina look going.....:cool:
Likes: KevinsBikes
