Schwinny
Im going through stuff at the collective and find boxes stuffed in a display cabinet full of high end stuff. Then another, then another....
"Oh yeah, those.. "THE GOODYS BOXES. We haven't sold anything out of there in a year."
Its not a wonder, its stuffed away.
So I've got the ok to get rid of things. This is all the approved for sale Campagnolo stuff. If you are looking for Deor, 150, 600, Simplex, Huret, Suntour whatever, Shimano whatever or any other specific parts, let me know and I will look.
If it says "Tipo," it means stock Campy parts, no specific name, just marked Campagnolo
I will get the spoke holes on the hubs posted soon. Assume 36
Everything listed is pictured on the table. There may be dirt, oil and small, light scuffs but no damage to anything here.
Shipping is 6-$16 depending on size.
All prices are somewhat negotiable.
Post to hold, msg with questions and to buy.
1 - Record Titanium Seatpost 27.2 / 8.5 Long. $150
1 - Tipo Alum Seatpost 26.4 / 5.5 Long $30
1 - NOS OS FWhub Body for 9/10/11 -94.99 new. $30
2 - Front skewers $20ea
2 - Rear skewers. $20ea
2 - plastic cap crank bolts $20set
2 - metal cap crank bolts $20set
1 - Gran Sport headset. 1-3/16" or 30.2mm head cups (for 29mm head id) All steel. Loose bearings (come with) $30
1 - set Veloce Calipers. $35
1 - Tipo freewheel Rear Hub 36 hole w/skewer 5spd $60
1 - Mirage 36 hole F/hub. $40
1 - NOS Mirage 36 hole f/hub no axle $30
1 - Chorus 32 hole f/hub. $40
1 - Tipo f/hub. 32 hole $30
2 - Blue Grey Brake levers. Levers only, no bodies / w/ locks $20set
2 - Drilled brake levers. Levers only, but one had body. $20set
1 - Tipo Alum crank set marked 172.5/ 93 / 9/16" x 20. $60
1- set Ergo BRFTRS. 9spd? 11 speed? $60
1 - 9spd stamped cassette. $20
2 - 8spd stamped cassette. $20ea
1 - 11spd very lightweight machined cassette. $45
1 - casette lock ring $15
1 - NOS BB cable guide / plastic w/screw / packaged. $15
1- Alum toe clip. single hole attachment style - $20
Chainrings
52t tipo lone
40t tipo lone.
52t polished tips lone
53-39t eps set
42-30t set
52-40t EXA set
52t lone from a 52-42t set/
$20 Singles / $35 for sets
Chainrings
52t tipo lone
40t tipo lone.
53-39t eps set
42-30t set
52-40t EXA set
