I’m refreshing a ND model D hub and ordered some replacement parts. The transfer spring I received is quite a bit different than the one installed. It’s slightly narrower with a different shaped protrusion:
Has anyone seen this on replacement parts? My original one seems fine so I may just use it. Also, the last time I rebuilt this model hub I ended up with a slight shift to the left when the tire was mounted in the frame (it wasn’t centered). What could cause this?
Finally, the disc pack in this hub only measures .71" even though it has the correct number of discs (12 steel and 11 bronze). I assume its correct to add another of each to get the thickness of the pack to .75", correct?
Thanks
