Remember that rear hub I said I liked? Not so great after all. The axle was bent, no big deal. I was toying with the idea of ordering a chrome moly axle because they hang out a mile and get bent on freewheel bikes. I decided to try and straighten it first. It was really hard to bend. Maybe it is chrome moly. When I put it back in the hub it was still bent. So, I tried again. Still off center on the freewheel side. WTF? Two or three more straightening attempts later, on bends so small I had to use feeler gauges because I couldn't see the bend, it was... still bent. Bah.
I have never had so much trouble straightening an axle. On close inspection I realized it really couldn't be the axle. After some wheel spinning while feeling the edge of the cones, I had about convinced myself the cones were machined wrong. I tried the ones from the front wheel because they are identical. No improvement. WTF? After spinning the wheel a little more with my finger against an unlocked cone I realized the bearing cups were not parallel. The are the pressed in replaceable type, so I put a punch through the back and tapped on the lowest spot. Massive improvement. I dribbled in some wicking loctite from the back side. I wonder if the freewheel threads will be straight?
I replaced all those steel nipples, and one spoke that broke in the back wheel, greased up the bearings and trued the wheels. Things are finally looking up. I put the tires on and pumped them up. Remember, I removed over 50 goatheads from each one(!). The back one stayed up. The front didn't. I couldn't find the leak at first, after all it is full of green slime. It is split by the stem. No LBS today, it's Sunday, so I picked up the only thing I could get today, a slime tube from walmart.
I don't think that kevlar(?) thing was supposed to come off of the old tube, but I peeled it off anyway and put it back in.
And finally, I have wheels.
The dork disc didn't make it.
Unlike most bicycle fans I don't hate dork discs, at least the metal ones. The plastic ones are garbage. I couldn't find anything approptiate in my junk and IIRC all the ones at the LBS are plastic, so I guess it will have to do without.
The rims remind me of something even more than the Weinmann 519. Maybe some 1990s Araya? I think so. Anyhow they are "HJC". They seem slightly oversize, and are a little hard to slip the tires on.
I took the derailleurs apart and cleaned them up. On the front one I straightened half of the z-bend. That puts the bolt out at a goofy angle that looks about like the older model Falcon I posted earlier that had a built in cable stop. I think it will clear and work fine now.
On the rear derailleur the top pivot post was loose on the claw. A little 56% silver solder fixed that.
Ready to go back on the bike.
I'm not avoiding those grip shifters, I swear.
