I
irontrader
Guest
1. Where can you buy tires for old bicycles? I've searched via Google and haven't found a good site yet that sells tires for vintage bikes.
2. What size tire do I need? The rim is 1.5" wide and about 25" in diameter.
3. How do you get the old tire off? Cut it off? The front rim is bare, but the rear rim still has a tire on the rim. The tire on it now is flat and no apparent sidewall to get the size info from.
All the above are for the early style metal rims which used tubular(?) tires which I've read somewhere are glued to the rim.
Thanks for any help or advise.
