I had talked about tire size on hear before but can't seam to find it now.The Ross bike if found needs tires on her the size of the tires are 26x1.75 Schwinn Spitfire,are these special size tires or will I be ok with any 26x1.75 tire Thank's.
26 x 1.75 tires may be hard to find so you could probablyuse a 26 x 1.90 or even a 26 x 2.125 balloon tire. Balloon tires arent as large as they once were due to manufacturers scrimping on materials so you can easily fit a modern 26 x 2.125 tire on your rims. Same with inner tubes, you will find that the tubes they sell are much smaller than the original manufactured size.
