rustNspokes
The first is an olive green frame with ornate gold scroll work and slightly larger than normal diameter tubing. It's fully lugged. Serial on bottom left hand side of head tube (323583 or 823583)
The second is has a partially split bottom bracket (just where the cups are), "D" shaped chain-stays, square socket crank nuts and an aluminum chain-guard. It's not a lugged frame. Serial number on bottom bracket (340197). Four badge holes in rectangular pattern.
