TOC Lady Chainless Columbia
JEAN MARIE
Mar 3, 2016
18
22
61
#1
Hi ,
I'm happy to have found out my third american bike , here in France ; confirmed by Mr Columbia it dates from 1900-1910 , and even 1900-1901 if the trophy fork is original
here some pictures , and more reading in french here
http://forum.tontonvelo.com/viewtopic.php?f=49&t=35229&p=366243#p366243
any idea of what would mean the crest stamped on the right of fork head ?
thx in advance for any comment and assistance in getting missing parts : headbadge, fork plate, front wheel
dnc1
1,466
3,451
52
Wallingford, Oxfordshire, UK
#2
Hi ,
Nice find @JEAN MARIE. Very difficult to read those markings on the fork crown, looks like some type of part number for the fork, but that wouldn't account for it appearing on both sides of the fork crown.
maybe try rubbing some dirt, or use a non permanent marker pen on the markings,
wipe off the excess and take another photo.
c'est très difficile à lire.
Likes: removed
JEAN MARIE
Mar 3, 2016
18
22
61
#3
Hi Dnc1,
thx for your comments ; and first my best wishes for 2018 !!
here are some more pictures of both sides of the fork head ; now , I really wonder if these marks have any meaning , or if they are just the result of some assembly process ?
3 first picts are the right side , where some sort of " crest" is present ; the last one is the left side, where some light marks are present
Likes: removed
Craig Allen
91
197
64
Millville NJ
#4
They look like dings to me. However the small circles on the fork head are frame pins that are used to hold the bike together during the brazing process.
Likes: dnc1
ejlwheels
Sep 7, 2006
639
150
Minneapolis, United States
#5
I believe the trophy fork without the steering tube clamp at the top for the neck is 1899 only.
I believe the drive cover plate is 1900 or later.
JEAN MARIE
Mar 3, 2016
18
22
61
#6
Hi ,
thx for your comments , unfortunately my technical english is too poor , and reverso as well , to well understand what you have written
by dings do you mean small dents made during manufacturing process ?
and EJLwheels, could you please post a picture for each type of fork you describe , the one of 1899 , and the one after 1900 ?
Craig Allen
91
197
64
Millville NJ
#7
The dings or dents were not caused by the manufacturing process. They are there simply as a result of time. The bicycle is 100 plus years old so you have to expect dents and scratches.
ejlwheels
Sep 7, 2006
639
150
#8
1898 trophy plate fork with stem/neck clamp
1899 trophy plate fork without stem/neck clamp
1900- plain crown fork (still without stem/neck clamp, but not shown in illustration)
JEAN MARIE
Mar 3, 2016
18
22
61
#9
Graig, that makes sense ; do you know where should I look for any markings on the bike ?
thx Ejlwheels for the pictures ; it's now clearer to me ; when you write " the drive cover plate" , you mean the one protecting the front gear ?
based on your experience, may we say now that my bike is from 1899 or 1900 ?
Likes: removed
Craig Allen
91
197
64
Millville NJ
#10
The serial number should be located at the top of the seat tube on the right side. Columbia also offered to engrave the original owner's name on the trophy plate on the fork head.
ejlwheels
Sep 7, 2006
639
150
#11
Your frame is definitely not 1898.
Your fork might have been an 1898 fork whose clamping top has been cut short,
but now at least it is basically a 1899 fork.
Beyond that, it is difficult to say without seeing it up close.
It is likely not 1899, because the seat post clamp would then be a collet style using a 1" diameter post
rather the the pinch bolt yours appears have. (Could that hole have been drilled later?)
Below, 1899 only seat post collet clamp:
Does the seat post clamp bolt hole look clean and countersunk like this? Then the frame is probably 1900 or later.
Your drive side cover plate is 1900 or later, but the crank arm looks like 1899.
Here is 1898, sharp right angle with not much shoulder.
Here is 1899, flat cover plate, right angle bend with well-defined shoulder.
Here is 1900 and later (all interchangeable) softer angle and less defined shoulder. Cover plate is stepped, not flat.
From your pictures it seems that your frame and fork could be 1899 with a replaced 1900 or later cover plate (not sure if a 1900 or later plate will fit on a 1899)
or a 1900 (or later) frame with a replacement (1899) fork and possibly 1899 crank arms.
A 1900 frame should have 1 1/8" diameter tubes. I believe later frames have 1" diameter tubes.
JEAN MARIE
Mar 3, 2016
18
22
61
#13
ths a lot guys for so many usefull answers and pictures
at least , we are progressing
I have measured all diameters : the lowest tube and the saddle tube are 28,6 mm , ie 1 1/8 inch , ie from 1900 onwards
FYI , fork tube is 35mm, upper tube is 25,4 , oblique rear tube is 19,5mm and gear and opposite tube are 22,3 mm
for the saddle , the seat post clamp bolt hole looks clean and is countersunk
then the cover plate is like the 1900 plus
about the saddle clamp, they may have done different versions depending upon the model ; as you can see on the 1907 Peugeot catalogue below , the standard lady bike has a hole and screw, when the " de luxe" model has got the conical screw we see on the Columbia 1899 model
I know it well because I've bought recently one " de luxe model " , you can see it here :
http://forum.tontonvelo.com/viewtopic.php?f=49&t=34229
the pleasure I took to fix the front wheel was great !
Likes: removed
JEAN MARIE
Mar 3, 2016
18
22
61
#15
Forgive my ignorance but are these chainless bikes very valueable? Can anyone throw out a number for a mens or womens bike.
Thanks
Chase
Hi Sacket ,
no precise idea, but you should contact MrColumbia , ie Kenneth Kowal , who is an expert in this field
prices actually depend upon the status of the bike ; anyway spare parts are looked for , and may cost a lot ; for example I need the headbadge and the scarce ones on sale on ebay are expensive for me ;
Likes: removed
$20.00
$20.00
$120.00
$95.00
$63.97
$199.99
$63.97
$10.00
$26.95
$18.00
$38.99
$35.00
$150.00
$45.00
$5.00
$125.00
$65.00
$16.50
