TOC REPRODUCTION COLUMBIA PEDALS WITH RUBBER INSERTS - LIMITED RUN!
$650 + $16.00 shipping to lower US States.
Carlsbad, CA.
mike cates
LIMITED RUN of Reproduction COLUMBIA RUBBER INSERT PEDALS NOW AVAILABLE.
Finely made reproduction COLUMBIA pedals made from steel and nickle plated as originally done.
Exact copy extruded rubber inserts specially produced from a custom made die for this style pedal.
Axles, bearing races and nuts are hardened and tempered steel.
Loose ball bearings just like the originals.
COLUMBIA script stamped into the faces of the pedal frames.
Outer bearing end caps are made like the originals.
Outer end plates have radially stamped Columbia name and Patent date.
Threaded ends are 1/2”-20 right and left hand threads per pair.
Both width sizes available: Man's 3 5/8” wide and Ladies 3 1/4” wide.
I've also made one pair of Man's 3 5/8" wide pedals with 9/16"-18 right and left hand threaded ends.
This is a LIMITED RUN of pedals and there will be no more made after these are gone.
$650 per pair plus $16 shipping to the lower US States.
Mike Cates
Cell: (760) 473-6201 Voice Calls Only and I Do Not Text
Email: cates0321@hotmail.com
Hoagie57
Mike Cates
Now those are SWEET 👍 But to rich for me GLWYS
