TOC Straight-pull 'Knockout' Axle Hub Set
Richmond, VA
Jesse McCauley
McCauley Cycle Works
Excellent original set of hubs that will help set your machine apart from the rest!
This version of straightpull spoke is relatively easy to emulate by modifying a standard spoke rather than the ball end etc variations which require more specific spoke heads.
Both hub spin smoothly, one has a small chip out of the outside of one race (as shown by the coaster peg) but does not effect function.
In the correct setup of these hubs there is a small notch that sits inside a recess on respective sides of each hub, this allows for that side of the axle to "nest" and the other side to tighten the axle.
32 Hole front
36 Hole rear
Oversized 11 tooth cog installed -
Please feel free to ask any questions
Barter is always an option
In order to give folks a fair chance and run transparently I am going to run this lot for 24 hours ending at 7 AM EST on 5/28/23.
Shipping will be $10 CONUS should a deal be struck.
Happy Hunting Folks!
