the T.A. thread is unique at 23.0mm pitch diameter
the common thread, found on "most" cotterless chainsets, is 22.0mm pitch diameter
old Stronglight is unique at 23.35mm pitch diameter
beginning about 1978 this changed to 22.0mm
once you damage the puller threads on an alloy crank arm you are a bit up the creek
one thing you can do is to pull the arm with an automotive gear puller
the Schwinn/Park tool is standard 22.0mm on one end and 23.0mm on the other for use on T.A.
before starting tool in opening make sure threads on arm and on tool are clean
use lubricant so you can easily feel what you are doing
it is possible to cross thread the tool damaging the threads on the arm
the 22.0mm size will wobble about a bit in a T.A. arm
