Miq
I've been riding around for a while with a period correct bell that looked great. Unfortunately, it liked to continuously ring. I had gotten used to riding with a finger or thumb resting on it, but any time I needed to use that arm off the bars, it would jingle away.
@SirMike1983 got a great looking bell for his sweet 1930's Phillips that seemed to be a possible fit for my 41 New World. The bell is an Origin8 Time Clock bell. It has a brass finished bell and stainless steel striker. The parts that hold the striker and attach the bell to the bars are yellow chromate finished. The bell sounds great, and rings for a long time, but doesn't ring at all unless you strike it.
It is styled like an old bell, but since it is newly manufactured, it is bright and shiny. My 1941 New World is a rat bike. It has a lot of wear and corrosion visible on it and a bright shiny brass bell just didn't look right. I spent some time this week trying to age the bell to look more appropriate on my bike.
I took the bell dome off the assembly and soaked it in a pyrex dish of pool acid. I wanted to remove any lacquer or clear coat on the brass. What actually happened was I removed ALL the brass finish and revealed a shiny copper bell. This bell is made in Japan and is offered by other brands. This one sold by Crane Suzu is obviously made in the same factory and shows the true copper bell:
I mixed up a solution of white vinegar and salt (a lot), and spent a few days trying to age the copper, I sprinkled the dome with the solution and let it sit in a glass cup inside a plastic bag in the sun. It was SLOWLY starting to get some color, but I could see that it would take weeks to get something close to aged enough. I broke out the propane torch today and sped thing up a bit.
I sprinkled all the parts including the striker and mount with the vinegar and salt solution then brought them up to a high temperature using the torch. The copper bell aged nicely and I sprinkled it a few more times while I torched it. The striker and mount also aged well. The yellow zinc turned gray and the stainless striker got hot enough to slightly bubble and blacken the surface. I'm sure all kinds of dangerous noxious fumes were created from this and I stood up wind as I watched it age 78 years in a matter of seconds.
After the parts cooled, I gave them a good bath and dried them. A coat of synthetic car wax and soft buff made them look perfect on my bike. One thing to note, the spring steel looses some "spring" when you heat it with the torch. It still rings fine and works great, but the spring also seems to have aged a bit...
I'm sure there are easier ways to achieve a similar look, but this is what I did.
My left arm is finally free!!
