RustyHornet
You are correct on the sprocket. It’s one I had laying around. Needed period correct 1/2” pitch.The chain ring front sprocket in post #12 looks like those on Premier Chicago bikes.
I believe that the drive pin configuration on earlier Mead bikes and some Miami bikes were fairly compatible (if not the same).
Perhaps that explains the offset installation shown in the original post, (because the Snyder-or-similar sprocket hole didn’t fit the Miami crank?).
