Andrew Gorman
I'm looking at a leaky and crispy singletube tire and thinking that it might be possible to add an innertube.
In its current condition, the outer casing is still pliable, but interior layers are dried, cracked and leaking air from every pore. The quick fix would be to make a small cut on the rim side, shake out the debris, and thread a tube cut in half through the tire, then patch the tube like a worm's clitellum. Not really optimal, but it should hold air and be ride-able with care. The cadillac job would be to peel back the base tape and slice the whole carcass open treating it as a sew-up tire. A lot of hand sewing, but I don't see any reasons it wouldn't work.
Has anyone tried this?
See any reasons why it just won't work?
Have any other ideas?
Thanks in advance!
Thanks in advance!
