Got kind of a late start this afternoon but got both bikes broke down and ready for the O.X. bath.
First I built a box outta some scrap 1x8 and 2x8. .Because I used some hunks of wood that were laying around I did not cut them to size and used them " as is". Should have had the 2x8 a bit longer as it is a tight fit. The bigger the box the more O.X. solution you will use . So you don't want it too big.
Next I lined the box with plastic with 3 layers thick. [I did this once during the winter in the basement with only one layer and it wasn't a pretty sight with a lake of O.X. on the floor.]
Next I filled 4 five gallon buckets with hot water, each with 4 heaping tablespoons of the Oxalic Acid [wood bleach] mixed in. It is important that whatever you do, that the object be completely submerged in the solution. You cannot say, because of container size restrictions, soak only half a big object. Deciding to soak the other half afterwards.
There will be a definite line showing between the two soakings. [ learned that the hard way]
Notice on this next photo the pin striping on this frame. Very rusty. In some cases not visible.
Now look at the last photo of this same area after being in the solution for FIVE MINUTES! While I was dumping in the 3rd. bucket of solution the O.X. had already brought out the whiteness of the striping .
I started the soak at 7 p.m. tonight. I have the alarm set to remove at 1 a.m. tomorrow morning.
I have found out that 6 to 8 hours works best. More then that we start flaking paint off. Because the acid attacks Iron oxide[rust] it is not real friendly to some red paints.
