Unknown, help needed please.
dnc1
1,758
4,491
52
Wallingford, Oxfordshire, UK
#1
I recently spent the day with my friend Jaume in his workshop in Mallorca.
While I was there a friend brought in this conundrum, I think it's 1920's to 1940's, French or Italian, other than that I'm at a loss for ideas.
Ostensibly it's a fairly conventional 'roadster' type bicycle with typical period details.....
However, it has one very distinctive feature, it has a box section midway down the main frame, into which is inserted a vertically mounted leaf-spring, which serves as a sprung seat post.....
I didn't get a photo of the spring, it was made of four leaves, with a sprung saddle.
I'm familiar with the Vialle frère's 'Velastic' design and it's Italian 'Sintesi' variant from the 1920's, but this is different, with it's tubular, not monocoque frame.
There are holes for a head badge and a serial number on one of the rear dropouts.
Has anyone ever seen one of these before, or have any ideas?
Any help much appreciated, thanks, Darren.
juvela
Aug 2, 2014
709
1,001
Playa del Rey, United States
#2
Hello Darren,
Thank you for sharing this find.
Agree it must hail from the interwar period.
There appear to be markings on the arm of the coaster brake. Have you been able to make them out?
The bicycle's crank arms look to have markings, if not writing at least symbols. Are you able to see them clearly?
The bottom bracket spindle is hollow on the end; is it hollow all the way through?
Bottom bracket lockring appears it may have markings on its outer face.
The feature cut of the head lugs resembles a pattern NERVEX offered at one time. It is similar to nr. 86 (not an exact match).
Are you able to read the markings on the hub wing nuts? Looks like it may be C S E.
Seat stay cap treatment suggests France. If headset & bottom bracket thread and tubing diameters metric that would eliminate Italy as an origin.
Welded stem/bar set may be Schierano. Domenico Schierano was an Italian professional racer active in the teens and twenties of the past century. Stem and bar sets resembling the one on the bicycle were produced with his name well into the 1960's. Do not know if he began the company which produced them or if he licensed his name.
https://it.wikipedia.org/wiki/Domenico_Schierano
If bicycle from France the stem/bar set may be Centrix. They were most active in this era and closed in 1962.
If you could post the spacing of the headplate fasteners it might help a reader to make an identity suggestion...
dnc1
1,758
4,491
52
#3
Thanks @juvela.
I currently don't have any more photos; I'll ask Jaume to send me some more detail shots when he can.
Unfortunately, I'm back home in the U.K. now.
juvela
Aug 2, 2014
709
1,001
#4
...something to explore further upon your next Palma sojurn...
Likes: dnc1
juvela
Aug 2, 2014
709
1,001
#6
...well, one certainly would not wish to go in the off season, now would they? :wink:
in your daguerreotype request to Jaume you might ask for some drive sides including closeups of chainset and head.
Likes: dnc1
dnc1
1,758
4,491
52
#7
First batch of photos in, more detail to follow......
"Frame number" is 33, or is that a part number for the dropout part?
Frame looks well made, initially there was some discussion as to whether it might be a home-brewed 'special' but I think it looks too well made for that.
The shortest spring section is missing its forked end.
I wonder if Vialle or Sintesi ever built a tubular framed model or prototype later on?
I can't find any reference to this anywhere, these are two of their 1920's adverts......
The positioning of the leaf-spring box is closest to the second example I think.
juvela
Aug 2, 2014
709
1,001
#8
Thank you for the new information and imagery.
There is a letter G on the outer face of the left dropout, possibly to indicate gauche which would be consistent with a french (or Walloon) origin.
Treatment of expander bolt seat for the head on the stem is consistent with the Centrix design.
Likes: dnc1
dnc1
1,758
4,491
52
#9
More photos, rear hub.....
Chain set.....
Fork details.....
Leaf spring leaves.....
Handlebars, seat post end section and remains of saddle.....
dnc1
1,758
4,491
52
#10
There is a letter G on the outer face of the left dropout, possibly to indicate gauche which would be consistent with a french (or belgian) origin.
Thanks, hadn't noticed the 'G', I'll ask if there's a corresponding 'D' on the other dropout.
juvela
Aug 2, 2014
709
1,001
#12
Muchas Gracias por Jaume for all of these excellent detail images. ;)
regarding chainset -
the round chainwheel nuts must feature splines to keep them from turning when the square-headed bolts are tightened.
Etablissements A. Haubtmann ( SOLIDA brand chainsets) offered a chainwheel of this pattern for at least several decades.
In the advert below the chainwheel on the left is of a thread-on design which affixes to a threaded flange on the crank arm. A lockring similar to one found on a bottom bracket assembly secures the chainwheel to the arm.
Likes: dnc1
juvela
Aug 2, 2014
709
1,001
#13
Here is hoping that both Jaume y la bicycletta be on high ground...
Likes: dnc1
dnc1
1,758
4,491
52
#14
Unfortunately Mallorca, and mainland Spain are frequently plagued by such events. I understand 9 people were killed in the floods this week at the eastern end of the island.
BradL
Oct 17, 2018
10
25
56
Cypress, TX
#15
This may or may not help, but this is a photo I found in a small book I have concerning the history of bicycles (La Bicicletta by Fermi Galbiati and Nino Ciravegna). It’s described as the Gran Turismo model by Officine Sintesi in 1924.
dnc1
1,758
4,491
52
#16
Many thanks @BradL.
I mentioned earlier in this thread that I was familiar with the "Sintesi" and "Vialle Freres" variants with the monocoque, pressed steel frames, but that photo is new to me.
I've only ever seen roadster style handlebars on these machines before, never a drop-barred example.
Thanks for the book information too but I'm unsure if that date is correct, will have to recheck original patent date. Interesting!
dnc1
1,758
4,491
52
#17
Original patent dates to 1923/24 so the date quoted is probably correct.
I'm still thinking the mystery bicycle in question is a later example, or possibly a third licensee of the original patent.
Likes: BradL
juvela
Aug 2, 2014
709
1,001
#19
Images not showing for me.
Are others able to view them?
Perhaps a browser issue at me end...
3-speeder
Dec 26, 2017
270
441
Lansing, MI, United States
#20
Viewing the images of the completed machine here while sipping my coffee. Hope they come up for you. Cool looking bike. Never seen one like that
