Started working on the "mixed parts" bike. Removed the super nice crank , chain ring and truss rods and installed on future Rollfast project.
Replaced the Rollfast crank and chain ring and will install the post war girl's Shelby fork.The head tube on the pre-war Rollfast is shorter then post-war boy's bikes. Since the Shelby fork is off a girl's bike it will have to be shortened.
The issue is NOT to chop it down the exact measurement required for the pre-war Rollfast frame. I will cut it down to fit a post war boy's Shelby frame instead.....so in the future this fork will work on a post-war boy's bike if ever so desired.After being cut down and re threaded it will still be too long for the pre-war Rollfast frame. The overage will be taken up by installing deeper headset hardware and extra lock washers if needed.
Notice the amount of the fork tube protruding above the head tube to be removed in photo above.
Took a break and ate some cheese I was aging from 2013...really good, .....Oh yeah ,the bike...where was I ??
Next a little "threading down". Shelby Co. ran the fork's key -way longer then necessary so the key-way slot will not have to be lengthened.
Finally, cut off excess using nut as guide......I selected deeper head-set hardware to cover the excess thread amount....maybe a couple washers too...Now this springer's future use won't be restricted to a pre-war bike.
Next up : re-painting the Shelby springer to match this tired old frame......
It's evening now. Springer has been cut down; threaded and gotten a coat of black paint. Time to install.
