I found this after I answered your PM earlier - https://www.ebay.com/itm/Vintage-NO...e=STRK:MEBIDX:IT&_trksid=p2055119.m1438.l2649 - it has the required 16 spoke holes. If the hub width and axle diameter match all you'd need is some replacement Torrington velocipede spokes which are easy to come across. If this hub is a bit narrower you could just add a spacer between wheel and frame.
