Victor Overman 1899 hub cones and covers
Rusty McNickel
For 1899 Victor Overman, I am in need of two hub cones and covers. They are typically pressed together however I do have two cone minus the covers. I'll take the covers if that is all that is available as that is all I really need or I will take the pressed together cone and covers. I would suspect they would be found assembled together.
Although Overman used the straight pull hub design for several years, I do believe this particular design and more specifically the covers were used only on 1899.
To add, 1899 Overman used the same diameter hubs, cones and bearings on front and rear so it doesn't matter which....
