Vintage Whizzer Belt Tension Help
Henryford2
Jan 28, 2017
276
67
North Ridgeville , OH
Need some guidance. This is my first Whizzer build from parts. I’ve read as many posts as I could find on this and other forums on suggested techniques to tension both belts. I thought I was there, but found I couldn’t peddle the bike (too much sheave belt tension?) and after numerous attempts at moving the motor and rear wheel around to get the tension right, I decided to start from scratch.
I’m trying to get to the suggested 3/8” clearance between the pulley and the coil cover. Presently it’s at ¼”. I’ve shown the clutch spring setup and the position of the motor (tight against the seat post) and the resulting clearance. I loosened the motor mount brackets on the motor and swung the bottom of the engine in an attempt to increase the gap, no change (I’ve included a photo of the coil cover with a groove worn it showing that the gap was insufficient in the previous setup). The belt is a PIX A26. The center-to-center distance is 8”. I’m of the impression that swinging of the bottom of the motor does not change this gap, but changes the clutch spring tension. Any suggestions?
Want to get this right before I move onto the rear belt. As I understand it this is a challenging task on the vintage Whizzer generally requiring much patience and trial and error. Thanks in advance.
Reactions: Goldenrod
Thurman
Feb 26, 2017
155
71
Midway City
The belt guard is a critical part of the clutch. Placing the guard up as far as it will go without rubbing will provide the most slack when the lever is pulled.
whizzerbug
Dec 14, 2017
236
shirley long island ny
your engine is too far back ,try moving rear wheel more forward , on the pulley to coil cover clearance 3/16 is adequate when clutch is fully engaged
Henryford2
Jan 28, 2017
276
67
Thought that perhaps the reproduction coil guard insulator was too big in diameter preventing me to move the coil guard up. Took the insulators out and not the case. Unless I hear differently I'm leaving it as is. I have a box full of coil guards and they're all worn in the same place, so I'm assuming I'm not the only one that has had this problem over the last 60 years! Thanks
Henryford2
Jan 28, 2017
276
67
Yes, I believe this is part of the problem. I'm using an AX62 belt on a Monark bike. With the motor back the rear wheel was near the edge of the drop out. The belt was real tight. I'm guessing too tight causing me not to be able to peddle the bike. I've got an AX63 & AX64 belt coming, hopefully I can get the wheel back further in the drop out without being so tight. Thanks
whiznut
On Training Wheels
Jul 5, 2019
9
77
Yorba Linda, CA
Did you get your belt problem resolved? I believe a Monark takes AX63 belt for the rear wheel. When adjusting the belts on a Whizzer , you always set up the rear wheel first.
Set the rear wheel, WITHOUT THE REAR BELT ON THE SHEAVE, TO THE PROPER CHAIN TENSION as you would on a bicycle. Align the wheel in the center of the frame and secure
the bolts. INSTALL THE REAR BELT ON THE SNEAVE . DO NOT MOVE THE REAR WHEEL TO TIGHTEN THE REAR BELT. YOU ADJUST YOUR BELT TENSIONS, FRONT AND REAR BY MOVING THE MOTOR. ALSO MAKE YOU HAVE THE CLUTCH PULLEY AT THE HIGHEST POSITION, WITH PROPER SPRING TENSION.NOTE: the photo of the clutch pulley shows that the AX 26 belt is riding high in the pulley, which shortens the distance between the centerline of the flywheel and clutch pulley. Some pulleys have this problems because the groove was not cut deep enough.
whiznut
On Training Wheels
Jul 5, 2019
9
77
Yorba Linda, CA
Henryford2
Jan 28, 2017
276
67
Yes and no, I stepped away from this project for awhile (partly from frustration). I had already found out that I needed the AX63 belt, so I changed that, got the correct chain tension and tightened the belts by moving the engine, just as you had suggested. The problem I now have (the belt tension is not excessive) is that I can't pedal the bike, even with the compression release open. With the clutch I can pedal it but it's difficult. I changed the motor pulley when I noticed that the small pulley (rear wheel), was worn badly allowing the belt to sit lower in the pulley increasing the drag (making it hard to pedal?) Made it slightly easier. I have a stamped metal pulley that I'll try next. Without the belts the bike is easy to pedal and the motor with the compression release open can be turned by hand. So I've eliminated the motor and the bicycle as the cause of the drag in pedaling (may be right, may be wrong). Thanks for the help, I've gotten some time today, perhaps I'll get back to it.
bricycle
Nov 18, 2009
22,881
Chicago area west
Technically you should be using a 48 tooth* or smaller chain wheel so as to pedal easier. a 52 is hard to pedal with a Whizzer.
* I would put on as small a front chain wheel as you can stand... if you are far from home, you want it easy to pedal back if it breaks down.
Henryford2
Jan 28, 2017
276
67
Ok, now what do I look for in the search for a 48 tooth chainring (make, model, manufacturer of bike?) any advantage or disadvantage in going less than 48? Thanks
Henryford2
Jan 28, 2017
276
67
Thanks, I walked away from this project for awhile. I do have a 46 tooth chainring available. Thanks again
Lynchwrench
68
54
Ma/Fl
Not with a flat tire...
oquinn
Aug 10, 2011
657
Whizzer s are a pain in the a..butt.
I havnt been able to get my belr right on a shwinn knowledable wz and my pedal hits the belt gaurd. Knowledable help is there but hard to get to take a real look.
Most of the time i ride this thst i built up. I ride i almost every day and it is always adjusted and always starts up and moves my bike everywhere i like to ride.
I
Goldenrod
Mar 14, 2016
665
74
Schaumburg
For general knowledge only. Not trying to cause bad feelings. Whizzers are difficult enough to put on Schwinns. Other kinds of bikes are. . . .
1) Think of the wind in your face and the babe sitting on the handle bar. 2) Mind numbing distillates help. 3) Standing on your head and spitting nickels will relax you.
Vintage-Whizzer
Apr 2, 2017
231
Portland, United States
I didn't know what I was doing, but I assembled my first Whizzer and it worked right from the start, and I didn't use a manual. I installed my back wheel as if there was no motor. Then I installed the belts. With mild tension on the clutch pulley spring, I pushed and pulled the engine to where the belts seemed snug. For more ease I even removed the clutch pulley spring and sheave belt in order get the parts in the position I wanted. (MOST IMPORTANTLY) With the clutch lever engaged the clutch pulley always rubbed on the coil cover. I think that's just the way it is. Also with the clutch lever engaged my Whizzer would stall at any stops, that's because the pulley belt is round and still has friction. To solve this problem you will have to install the belt guard. The belt guard will prevent the belt from turning into a circle and instead keep it an oval shape so the pulleys can fit between the belt. Anyway, that is a problem you may run into when you get there. Moral of the story is, when you run into these problems don't go by the manual, but first try to make it ride-able and work, and then refer to the manufacture's steps. Maybe this isn't the best advice, but if it's not working you have nothing to loose. Okay you can loose your life, and maybe some money if your bike falls apart, so be careful. Also a smaller chain ring will give you more slack on your chain so more then likely you will have to remove a link. Don't give up!
