My suspicion is it's worse than that. I have one of them here, and I just remembered I left it outside. Oops. Last week we got 3 feet on snow. It had been parked in my neighborhood with a "free" sign on it for a few days.
Watching bike mechanics rail against them on youtube, you might think the main problem is the assembly. Things like no grease, misadjusted or misassembled bearings, forks on backwards, etc. Maybe at some point I will figure whether it is just terrible assembly or if it is rotten to the core. I have a sample here. It is a 24" full suspension mountain bike.
I had never heard of the brand, and I can't remember in now. At the time I got it home I looked it up. It turns out to be a Walmart exclusive from around 2008(?), and IIRC some of them were part of a CPSC recall for fork breakage. Mine was not part of the recall, either a little too new or too old.
At first glance it looks OK. I figured I would true the wheels, grease the bearings, etc and see what its like, find out if they are really that bad for myself. One obvious flaw, the saddle is a spandex one in shreds, no big deal.
When you look closer, some things are a bit off. The front wheel just looks too far back. The rear suspension at first glance did not appear to have a good enough pivot to be stable under weight and in motion. The suspension fork does not look terribly stable either. I think it's bent. Maybe the frame too. If the fork is bent, I wouldn't expect it to still move up and down, but it does. The bike has twist shifters. That's bad enough, but they are crappy ones and I have my doubts they can even be made to work. As I recall, nothing about the gearing was functional. I probably won't find out any more until spring. Maybe I'll get some pictures then.
Apparently this one was too cheap for Walmart to even put a Huffy badge on, but at least it doesn't have a plastic stem.
