Wanted: Prewar Schwinn deluxe headset cones. These are pretty shot.
Goes with this type headset. If there should be a keyed washer, then I need that too. I am not sure if one was used with the spring fork.
Both cones are a little under 36mm at the outer edge. This does not use an oversize crown race and lower bearing like the postwar set does.
I suspect the postwar deluxe upper cone would work, but I am not sure.
