War-time or maybe pre-war ladies Royal Enfield with undated SA hub
SirMike1983
On the no-date hubs: from what I have seen of them, probably right before WWII to early 1950s era. The no-date hubs I've opened all looked to be from the early years right before WWII through 1940s right after WWII. None seemed later than 1952 to me. And most seemed even a little earlier - 1940s era.
FICHT 150
The sprocket on that hub is retained with a split ring, war era hub would be threaded on the driver.
Neat bike.
Keep in mind the hubs from 1940 and prior had a single digit code, ie 1940=0
Ted
3-speeder
I was looking at my '39 hub, AW-9, and remembered that when I cleaned it up I didn't unthread the sprocket from the driver. As you noted this one has the three tab sprocket and split-ring. I figured it was a later model than that one. I'm still thinking the bike is war era. Perhaps the 3-speed was a later upgrade? That might explain the chainguard.
Upchuck79
Great pictures - this is very helpful to those of us who have old Brit bike parts collecting dust. Just the impetus I need to pull out the Sunbeam and post pictures to benefit from the CABER input. Thanks for posting the as is, updates on the progress you are making along the way most appreciated.
3-speeder
Thank you. Can't wait to see your Sunbeam. Definitely some experts on here that have helped me out. I've found that my favorite thing about these old bikes is bringing them back from abandoned wrecks and getting them on the road. I'll update this thread when I get this one rolling.
Upchuck79
3-speeder - pulled these parts out of a basement - CABER's have advised this is a '36 or '37 Sunbeam. Missing the guts for the rear hub - assuming this was a three speed and will have to collect missing cables, etc. Wheels and spokes look good and should clean up well. Will follow your progress with a keen eye. Do you get parts from the UK or can you find them stateside? GLWTR!
1419551
1419552
1419553
1419554
1419555
1419556
1419557
1419558
1419559
1419560
1419561
1419562
1419563
1419564
3-speeder
I got started on the rehab of this bike. The disassembly has gone pretty smoothly which makes me again think that this was a well stored bike, most likely inside. Two days of pictures.
1435094
1435095
1435096
1435097
1435098
Both bb cups unscrewed easily with my pin spanner and the parts went into the degreaser. B W spindle.
1435099
1435100
1435101
When my project manager calls for a break, I take a break
1435102
1435103
juvela
thanks very much for this update! 🧑‍🔧
its always a treat to see the calibre of the older Brit headset and bottom bracket fittings vs what came subsequently...🚵‍♀️
will frame be vectoring into the soup?
inspector's portrait might be a good fit over in the feline portraiture thread at the lounge 😉 🐱
