Does anyone know of someone who can weld and shave unwanted holes in fenders? Hopefully someone who is reasonable and not looking to charge an arm and a leg!
Before you farm out your project , check out my pictures on my fender.
I had two factory holes for light, and I didn't want to spend a lot money
for a light so I just fill them in with silver solider, sand , and primer all
within one hour. If you decide to try this make sure you use
METAL WORK solider. Cost is about $10.00 Hope this help.
A Local High School?
Do they even have shop classes these days, though?
Any garage/muffler shop might be worth a try for quick braze or weld.
Drop by casually at lunchtime and have coffee and donuts nearby!
It should be the first job they get back to after/during lunch.
I just used JB Quick on a couple of holes in some old fenders and it works just fine. I used aluminum foil as a backer held with masking tape on the underside of the fender and filled in the holes thru the other side. This stuff sets like in 10 minutes then I hit it with 240 grit wet sand paper and it made a perfect repair.
