Welding repairs and fabrication
Dayton Vintage Speed
65
48
Dayton Ohio
I'm offering my services for welding repairs and fabrication on bicycle frames and sheet metal parts. I am an experienced sheet metal fabricator and welder with 30 years of professional experience in the automotive restoration industry. I am experienced in welding steel, stainless steel, and aluminum. I offer both mig and tig welding as well as oxy-acetylene and tig brazing. I offer a full sheet metal fabrication services. I can fix, straighten, and reproduce sheet metal parts. Feel free to PM me with any questions or a quote.
Barto
1,765
Somers, United States
Uggghhh, where were you two months ago. I took my tank to two body shops...they both declined. Had someone from my shop who was a former body man do it....it was less than expected. I ended up doing another repair and it's OK at best. BTW, Very nice work on the rack
bricycle
Nov 18, 2009
23,005
Chicago area west
well that's good to know, I'll have to put you on speed dial.
Now I just need someone to do Aluminum machining
65
48
Dayton Ohio
What machining do you need done? I have a bridgport in my home shop as well as a lathe and bridgeport at the shop where I work.
Barto
1,765
So, what would a charge be for the type of repair you did you your rear rack? Super nice job by the way!!!
BART
then8j
Oct 6, 2010
719
Walnut Creek CA
Do you have any more before and after pics of your work.? I tried fixing some stuff myself and we’ll....... it’s not very pretty.
Reactions: bricycle
65
48
Dayton Ohio
Yes.
This is a TOC Jenkins frame I just aquired. The tubes in the triangle are a little worse for wear. The down tube had a section of new tubing cobbled in it that was the wrong size and was crudely welded. I believe the bike frame was also used to drive rail road spikes at one time by the amount of dents that were in the top and seat tube. The rear chain and seat stays are in good order but the tubes of the main triangle are rough to say the least. The easiest fix for a straight tube frame such as this is to put sections of new tubing in. Here's a before pic of the down tube repair.
I cut the old 1 inch undersized tube out and cleaned off the remnants of its remains from inside tends of the original tube.
I fitted th he new tube and fixtures the bike frame so I could keep the tubes inline.
I welded the tube in place then finished the welds.
I'm putting a section in the top tube the using the same method.
65
48
Dayton Ohio
Of the things I commonly fix or repair are things like stripped pedal threads in old cranks. ( Most all have been TOC hard to find cranks. ) I machine an insert slug to size and drill the end of the crank arm out. I use a Bridgeport milling machine to drill the crank arm so keep it as square as possible.
I install the insert. If all goes well this is a press fit.
I then weld both sides of the insert.
I finish the welds off. Tap the hole to proper pedal size in this case 1/2-20. Then I re-patina the repair area if so desired.
Finished and pedal test fitted.
5760rj
Sep 19, 2017
977
92027
hello, have a Higgins rear rack and I want to install a NOS pair of 1948 buick roadmaster fender reflectors, support brace can be moved with a possible sheet metal brace/attachment to strengthen area and mount reflectors, rack will be high enough to clear fenders, what do think?
willswares1220
1,916
Port Washington, WI
Yes.
Beautiful craftsmanship!!!
