genesmachines
I recently purchased this bike, it looks to be 70s-80s, and am working to fix it up for resale. I need help to find the model of the shifter so i can adjust it so it goes in all gears properly. Its a 2 cable push-pull deal, if i adjust it to go in highest gear, it won't go in lowest. the chain tightener runs at an angle to the gears, is this normal for this shifter? I am a single speed guy so I know enough to be dangerous. I tried to show this in pictures. Also the disc brake stops like its working in poop, can this be made to work better. It looks to be about 1/16" space between pad and rotor with cable loose. Any help will be appreciated. Thanks much
