Mercian
Hi @Demzie
Thanks for taking the trouble to post your number. Yes, it's a 1945, probably in the first three months.
As you can see from the list, the dating system was changing at that point, and we still don't understand what was happening in 1945. When you get the chance, could you look to see if there is a two digit code on the bottom bracket too, above the serial number? It'll may be something like 2N, or N3, or nothing at all. This all helps.
Thanks,
Best Regards,
Adrian
PS, just reread your post, yes, the chainwheel is the correct type for this period, and if it was you that fitted the blackout ND hub, that is probably what it would have had originally.
Thanks,
Best Regards,
Adrian
