In my life, I have probably changed out hundreds of bike tires, but never have I had such a problem with these. I am changing out a new set of 26" x 1.95" MTB tires onto a set of 26" Matrix Swami alloy rims. The tires are so tight,I had to use steel tire levers as the plastic ones bent and cracked. I lubed the tires with a soapy solution. I ended up pinching the new tubes twice. I had to use all my might to get these tires on then, once on, I filled the front tube to 60 psi and the sidewall separated from the bead wire and blew my 3rd new tube. I assume it separated because I had to use so much force to get it on. I did have to use the tire levers to remove the original 26" x 2.10" tires, but not with any of the force I had to use to install the new ones. My local bike shop only had the 26"x 1.95's in stock. I thought it was the new tires, but I also tried some used 26" MTB tires of different widths and I am running into the same problem. I know swapping out tires isn't rocket science, but there is obviously something wrong. I feel as if I am installing the wrong diameter tires. The real PITA is I am doing this as a favor for someone.
