bikemonkey
Hi,
Would like the opinion of restorers on here, especially those who restore potential "show" bikes.
If I am restoring a classic bike and it needs cables, rubber, and chain, how does it affect the showability of the bike?
Say for instance, replacing the tires on a Stingray and I use the newer old stock Schwinn Approved rubber (with correct tread and lettering) made in the 90's? Is that acceptable?
Another instance would be S.A. three speed cables. Does it matter if the cable connector is the newer universal type (using new grey housing) or should I seek out NOS S.A. cables the correct length?
If using new brake wire and new brake cable housing and it is the correct color and I am using the old ferrules, is that acceptable?
Replacing ragged out S.A. axle nuts with genuine S.A. axle nuts, ok?
What about drive chains? NOS make a difference?
Thanks for your thoughts!
