Thanks rhenning and rollfaster for your replys, got another question. Does this frame came with an serial number? I cant find one or maybe it's under the coats of paint, where does this frame use to have it?
Like Rollfaster said it's a Hawthorne, sold at Montgomery Wards Stores. Could be purchased mail order or at their stores The serial #'s would be underside of the bottom bracket. Turn the bike upside down. May have to clean away some crud to see them.. Your bike was available with a nice springer that are easily found if you want to replace your fork. Your bent fork is easily straightened .
I believe these had a 'bee hive' springer but besides the fork requires a different fender and light. It is possible this model wasn't offered with a springer. V/r Shawn
Looks like it has the red and blue M/W badge, first used in '50. As a Snyder built, it should have the 2 digit year in reverse, plus two letters stamped on the bottom bracket.
