Whizzer Crankshaft End Spacer
Henryford2
Is the crankshaft end space set on a roller crank any differently than the standard bearing crank?
Crankshaft end spacer IS the same for either type crankshaft, be sure to check endplay if you are changing crankshaft and use the appropriate spacer thickness . John
Thanks, I wasn't very clear in my original post. My intent was to ask if "setting" the endplay is done differently for a roller crank than the standard crank. If I understand you correctly it the same method using the same spacers. Thanks again
