Who made a high-quality front derailleur to fit a 1" seat tube?
bloo
The title sums it up. What front Derailleur options exist for a 25.4mm/1" seat tube? I am not having a lot of luck on Ebay.
I am putting together a duplicate of a bike I had in the 80s (I'll post a thread about it when I get around to taking a picture of the pile of parts). I used a Huret back then to replace the lousy original, though I don't remember what model that Huret was, and I suspect most of them are for a French seat tube or larger. Ebay sellers don't usually include the tube size.
A Suntour Cyclone II with the endless clamp looks sort of promising, but as near as I can tell those have no housing stop, and I would really prefer a housing stop because I don't want to run the cable under the bottom bracket.
Chainwheels will be 40/34. What are my options? Also, is there anything modern?
PfishB
Decent quality but so-so cachet, probably outside your parameters but - Suntour Spirt FD's came in 28.6 and 25.4 That's the only one that comes to mind off the bat. Seems to be no shortage of those on the 'bay.
juvela
One thing to be aware of with the Suntour Spirt/Compe-V/SL family of front mechs is that they operate "backwards" from all others. They are referred to in the trade as being "top normal." This may take a bit of getting familiar with. The design definitely has numerous adherents. No wish to denigrate it.
Huret produced quite a number of models for 25.4mm seat tube.
Here is the Club II model as shown on a manufacturer's catalogue page of 1978:
1277182
All of the Shimano models have seen for 25.4mm seat tube are low end ones such as the Thunderbird series.
all riders
A lot of front derailleurs came in two clamp sizes and are often marked as such.---I think the average ebay seller may have no idea, so if you see one you like, you'd have to ask them to look. I might have something, I'll have to look, It would be period as I raced the things from about 78--85. What bike are you building?
bloo
Thank you for all the responses. I have learned a lot in this thread, and I suspect there is more to come. I am leaning toward the Suntour Spirt simply because it looks like it has the biggest stoutest hinge. I can live with it working backwards, although I see it clamps the cable and the housing moves the derailleur. That might get a little weird with modern stiff cable housing, but maybe it will be fine.
Chavez
Hello,
Wheels manufacturing makes a shim to go from 28.6mm down to a 25.4mm (1 inch) seat tube. If you’re wanting to go more modern, find a derailleur that’s comes with shims to get you to 28.6, then use the second wheels manufacturing shim to get it down to 25.4 (1 inch). That’s what I was going to do on some project many years ago. I bought the shins and still have them. I hope that made any sense to you. Good luck. There’s probably a direct mount adapter that could be used as well. Then you’d have some modern options too.
bloo
I didn't want to use shims because I figured they would slip. Also, it seems nobody makes a direct mount adapter for 25.4. I dug deep for that but it doesn't seem to exist. I would be back to using shims.
Gordon
I may have one of these also, I will look.
Chavez
Yeah I was thinking a direct mount adapter in a 28.6 might exist and then you could use the shim. Keep in mind that many if not most non-direct Mount modern derailleurs have shims that come with them from the factory. If you don’t like using shims, I totally get it. You want your bike the way you want it. I’m the same way. Good luck on your search. I’m sure you’ll figure out a great if not the best option.
bloo
Pictures of the Rainier project are over here:
Gordon
Here is a Suntour Spirt. A little dirty, but no wear, I'm sure it has never been on a bike.
1277326
1277327
1277328
bulldog1935
late to the party, but I would recommend the SunTour infinite band-clamp, which adjust to any size seat tube
This may have also been marked Spirt (when they meant Sprint)
