Actually those pictured above are listed as "Torrington 4-Star 1935" They have a pretty good finish and the sharps are SHARP instead of ground down nubs which means they weren't used too much.
The Record pedals on the speedplay pedal museum are different.
I do believe the Torrington 4-star is the same as the earlier Torrington 1 with exception of the pedal shaft cap. I have an earlier set that have "Star" stamped in script on the pedal shaft cap. It doesn't have a hex head, but a slotted depression instead. I think the hex head is an improvement over earlier design as I find myself having to tighten one of my caps on a regular basis. Another interesting note is that the caps themselves, hold the cage on the shaft. A flat ground on the shaft to match a flatted hole in the pedal cage keep it located at the proper orientation.
I think the pedal museum is a good place to get information, but I also think they are lacking some info as well. It would be great to see a more comprehensive listing with photos, but I think for Speedplay it's more of a short history of pedal manufacturing and design than an all inclusive historic resource.
All said and done, the scarcity of rat traps are driving their cost up. Someone must have boxes and boxes of them somewhere.
