Widen frame and fork fat tire monark super deluxe rides like a dream
Superman1984
Oct 28, 2019
415
36
Pageland South Carolina
@Rodger honeycutt would you mind showing on the rear where you made your cuts to widen it & post info on what was used to keep it looking OG ?
Roger honeycutt
31
59
Burnsville nc
I took a sisor Jack and put it between the rear drop out and spread the frame then took 4 inch pipe and put in the bends then took ratchet straps and secure the pipe to the seat post then played it on its side and bent it around the pipe you have to make sure ther bend evenly when I put tire and wheel in the frame was about 2 inches short so I extended the frame it puts a small crease where it meets the fram but not rely. NOticeable
